X/Y 5'- for coordinate input not working
OK - baffled here...
If I want to draw a wall starting at one corner - hover mouse over corner, input x5'+, cursor jumps to and creates a blue line in the correct spot as my offset point to draw a wall. This works in x/y axes. If I try the same with negative values i.e. x5'-, the cursor jumps to an arbitrary point in the y axes. Anybody have any input on this?
Eduardo Rolon
For Imperial Units using "Feet and Fractional Inches" when you are going to the left or down (negative axis) you need to write either 2 (-) or (-+)
• X5'--
• X5'-+
Reason is that after one dash AC is waiting for inches. This is not the case for Feet with Decimal inches and or Metric.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Awesome - thx Eduardo.
