ZONE AREA'S
I'VE BEEN CALCULATING THE AREA OF ROOMS BASED ON THE ZONE STAMPS...BUT I JUST REALIZED THAT IF I STRETCH A ZONE TO FIT A ROOM THAT MIGHT HAVE CHANGED SIZE, THE AREA ON THE ZONE STAMP DOES NOT CHANGE..GIVING ME THE WRONG SQUARE FOOTAGE. IS THERE A WAY TO MAKE SURE ALL THE AREA NOTES ON THE ZONE STAMP UPDATE WHEN I RESIZE THE ZONE?
19 Replies 19
Erika Epstein
"R.A.I." are you referring to the the Zone Reduction Area under the roof? If so, it reflects the settings in Working Units.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
This is the field in Project Preferences (in Working Units as Erika said) that controls it.
See attached image.
i have inserted in box "Decimali Angolo e Dimensione Testo nei dialoghi" the number 3, but in the Zone Room, the decimanl number of "R.A.I." is 0,09... I thought it became 0,090.....
it looks under at the image to understand...
thanks for the attention and excuse me for possible errors of language
Fabio
edit : "RAI" = "surface windows : surface room "
David Maudlin
Fabio:
I think the setting you are looking for is under Project Preferences > Dimensions > Zone units.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hello everyone
I would like to extend the conversation about the zone stamp of data management.
Seeking a way to automatically update the zone height. Would anyone can advise how to automatically adjust the heights of all zones to room heigh?
Erika Epstein
If you are asking is there a away to insert a zone and have it automatically read the height of the space it is in, there is no setting for this.
You must set the height manually or trim the top or the zone using trim
Design>trim zone
or trim it with SEO.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
New to the forum.
I am starting to work with zones and I have activated my finish floor level in the stamp.
Even though the zones I create are linked to different stories. The floor finish level always appears as +0 ay clues as to why this might be ?
Lingwisyer
Guru
From memory, that level only relates to the structural slab and cannot be used to reference a datum... You can instead use the Classifications and Properties content option to show Elevation to Sea Level if that was what you were looking for.
Ling.
Hi Ling,
Can you please elaborate on how to use the Classifications and Properties content ?
My finish floor level is say + 20,000 above sea level and that is what I want to display
Lingwisyer
Guru
In the Properties Manager, add a String Type property to the Zone listing. The value is:
CONCAT ( STRCALCUNIT ( {Property:General Parameters/Elevation to Sea Level} / 1000 ), " m" )
You can then add this under your zones Settings: Classifications and Properties... tab.
Ling.
