2013-06-21 02:18 AM
2013-06-27 04:01 AM
2013-06-28 01:25 AM
2013-06-28 01:32 AM
2013-06-28 01:41 AM
2013-06-28 01:47 AM
2013-06-28 04:24 AM
2013-06-28 04:59 AM
Chris wrote:Turn on your wall reference lines (on screen display option) and see how they all trim.
EDIT - I just tried creating quick wall rectangles and the zone tool seems to work fine - something must be messed up with the walls of my plan, but I can;t think what it could be.
2013-06-28 05:11 AM
Barry wrote:reference lines all appear to line up properly - doesn't make any sense!Chris wrote:Turn on your wall reference lines (on screen display option) and see how they all trim.
They will all need to connect to each other to create an enclosed space for the zone to place automatically.
Worse case scenario if you can't get the wall to trim together properly then set the zone to manual draw (in 17 you can now do a rectangle) and draw the zone yourself.
Barry
2013-06-28 05:20 AM
Chris wrote:It could be the smallest of gaps.
2013-06-28 05:34 AM
Barry wrote:Checked all the connections by trimming, then copied the walls enclosing one room to the side and checked the intersections again - no luck. Then i drew a quick room again and sure enough the zone works there - even though one of the reference lines didn't properly intersect! This is so weird - thanks for the continuing thoughts and help!Chris wrote:It could be the smallest of gaps.
The only way to know for sure is to force all the walls to trim with each other again.
Often I will drag a copy of the walls to the side so I can play with them and then it doesn't matter if I destroy them.
If you drag a copy and can place a zone in them then I wonder if there are other walls (other layers or duplicates) that are interfering.
