We value your input!
adjusting story settings
jimmyp
How do I adjust story settings without effecting existing building elements like walls, slabs, roofs, etc.?
PowerSquare Design
Denver, Colorado
Lingwisyer
Guru
That cannot be achieved within a single file. As an alternative, you could insert your current building elements into a new file as a Module in which case the Module Story Height can be different to the host files Story Height. You just need to make sure you check the retain story heights box rather than the adjust to host box.
Ling.
Lingwisyer
Guru
Ling.
jimmyp
Thank you
PowerSquare Design
Denver, Colorado
