all 2d elements disappeared in the section after rebuilt
As the subject, once I rebuilt the section, all the 2D elements are gone and I have no way to recover that. I still supposed that those 2d elements are turned off that I can retrieve them somehow.
What is the reason behind and any solutions?
Djordje
Which Archicad, machine, OS?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Erich
If you are using a particular view make sure the necessary layers are on after you rebuild. That could cause your 2D elements to disappear.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Jere
I've noticed the same problem in AC11.
The problem occurs when a Section has been converted to a drawing, then the 2d fills and lines are modified. When the drawing is rebuilt because of a change to the model, the modified 2d elements are deleted. Of course, any new lines and fills remain. The simple solution of course is to modify correctly so that converting to drawing is not required, some of us (ahem, me) aren't good enough yet to get the models to that point.
The solution? If you need to rebuild a section that is a drawing, copy all the elements first then paste them back in.
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
