2009-12-07 02:44 PM
2009-12-07 03:48 PM
another Moderator
2009-12-07 03:49 PM
The BLOCK command allows you to group items and then store them in a file so that they can be recalled as needed. The BLOCK command is frequently used in situations where a particular part or element is used multiple times in a drawing. This saves time by reducing the need to create the same item over and over.So you are essentially looking for Hotlinked Modules in ArchiCAD.
2009-12-07 04:20 PM
