‎2008-12-02
02:40 AM
‎2023-05-25
06:09 PM
Rubia Torres
‎2008-12-02 12:09 PM
‎2008-12-02 07:40 PM
‎2008-12-03 02:36 AM
laszlonagy wrote:
Since a Window can only be placed into a Wall:
Draw them as Walls and then place the Windows into them.
‎2008-12-03 02:41 AM
Karl wrote:sorry, I can't place the window without a wall
Actually, using the library 'bay' assemblies as an example, this does not need to be done with walls and inserted windows - although it certainly can be.l
You can model the entire bay assembly consisting of the extended sill (or floor), window frame, glass, ceiling and roof as well as a wall cutting slab with the ID=wallhole in the floor plan using normal tools and then save the entire assembly as a window. Placing the result in the wall will cut the hole.That mean I have to model whole window again? it is so inconvenient.....
‎2008-12-03 02:51 AM
‎2008-12-03 04:32 AM
angus wrote:The 'bay'Karl wrote:sorry, I can't place the window without a wall
