ā2023-10-18
11:11 AM
ā2023-10-23
07:29 AM
Me and my co-student both use Archicad 27. But after we send the file to each other all the objects and windows turn blue on the ground floor. This only happens to the objects we place after the exchange of the file. What can i do about this?
ā
ā2023-10-18 07:50 PM
Are you using the same pen set?
ā2023-10-18 11:02 PM
Yes everything is the same.
I just changed the objects in to morphs and now the color is normal. It helped but i dont think it is the right way.
ā2023-10-19 01:53 PM
So maybe Archicad is creating an issue for those changes, and the issue comes with this 25% blue graphic overwrite, you can go to the issue manager and chek if it has an issue
ā
Or the objects are classified or have an ID that your graphic overwrite is filtered to, changing the background fill pen.
Or is just a bug that i don't know of š
