brick surrounds
Bonsoir everyone,
Im trying to model some windows with brick surrounds. So far I can only find the option to have an arch of bricks over th etop of the window, not all the way around it. Does anyone know a way of doing this that wont take too long?
merci!
Lisa
5 Replies 5
You may be able to use what GS calls the "Quoins" object
in the masonry folder in the wall extras folder.
Peter Devlin
Create a slab, using the multiply with vertical increment, then add another slab for the mortar.
Snap
PS
...or create a beam profile in the shape of the window surround. Place it through the wall (perpendicular). It makes the penetration automatically. For mortar joints and/or rustication you can make additional profiles and extend or recess them as necessary.
Cadimage's Door and Window Builder will do this. See image below. While I haven't explored all the settings, if you select a Head moulding option you can do away with the mitred corners too.
Thank you very much for your replies guys, some very interesting ideas which I will definately look at when the project developes, for the moment I will draw in a symbolic representation using lines as its too much time at this stage.
Sart, thanks fo rth etip on imagecad, i guess I have to pay for this? Im disappointed that something as basic as this should have to be paid for as an extra, when brick arch is already available, why not a surround for the whole window?
Regardless, many thanks once again for your help generous forum users!
