2004-01-24
03:32 PM
2023-05-25
05:36 PM
Rubia Torres
2004-01-24 05:21 PM
2004-01-24 06:14 PM
2004-01-24 07:25 PM
Petros wrote:I would work by stories. What is on a storey, should be there. So, divide your cinema vertically into levels A, B, C. Wall is also split to A B, C. Everything is. That way, you can even use MODs (one storey only) for the eventually same layout.
I was refering to the rows/steps of the cinema and not the furniture on top of them( which can be easy be solved in the way you described.)
I used a stair to represent it, but by placing the stair object appears as an outline projection on the lower level.
Also my question about the side walls and the use of accessories was that if you use walls on each floor then you have to create different wall accessories for every floor. That means that you don't have total control on the full height of the wall. Problems also apear when you want to use SEO's between side walls and the stair used for the floor. I also considered the use of slabs...
2004-01-24 09:43 PM
2004-01-25 05:48 PM
