composites in AC17
Is there a way to override the wall composites? In previous versions you had the option of using the composites line colors or not. I have a building shell that I'm doing a TI on and I want the shell walls to show up as a specific color and not what is dictated by the composite. I would like to avoid a second composite if possible.
4 Replies 4
David Maudlin
doober922:
Not sure this is what you are looking for (a screen shot would help) but have you tried in the Wall Settings dialog box Floor Plan and Section > Cut Surfaces > Overrride Cut Fill Pens?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I was able achieve what I wanted with the renovation filters.
I haven't really thought through this problem very well - or maybe I have and I just got my Friday brain in.
But how do you over-ride the fill AND cut lines in 17.
You can do one or the other or create a completely new composite for each wall using each line type - that would be 100's if not 1000's of extra walls.
I think the following images will explain what I mean.
An in 16 it easy to have a wall where you can over-ride the fill pens and the cut lines at the same time.
How do you do this in 17?
