Dave Brach
copy/paste warning
When I copy/paste a wall from one story to another I get the message "some of the elements you are trying to paste are hidden in the current renovation filter" even though the renovation filter and the elements are identical between stories.  In this case the wall is set to show on the renovation filter on each story.
Dave Brach/architect AC28 Macbook M4 Pro OS Sequoia
4 Replies 4
CosminF
did you check also if the doors and windows in the selected wall may be the culprit?
or try the same thing with a “blank” wall, to see if you run into the same issue.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Dave Brach
Hi, thanks.  The "blank" wall does not have the issue.  But any wall with windows and/or doors has the message, even though the windows and doors are set to "existing/show".  It's a minor thing.  If other people don't have the issue, must be something with my favorites.
Patrick M
Ace
are any of them pinned to a renovation filter combination?
Dave Brach
nothing is pinned.  I tried adding a random door from the library and it worked fine.  Then I tried a door from my favorites, and I got the message again.  Under door settings>renovation, renovation status is "existing" and show on renovation filter is "all relevant filters".  But it definitely is the door/window.  My guess is the favorite was created multiple ACAD versions ago.
