curved sloped rock wall
I need to model a curved, sloped rock wall. The wall is actually a vertical wall with a sloping rock veneere on one side. What would be the best way to model a curved, sloped rock wall?
Thanks,
John
15 REPLIES 15
TDabney
Sounds like a mesh to me.
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
May be u addons from cigraph archiwall ,according to me its the only option,if iam not wrong r u trying to build a castle wall with varying thickness on the outer suface with circular profile,if thats the case,try out this addon.ie archiwall u can do it
It makes a difference if it has windows in it or not. If it is a battered stone wall without windows, profiler would work well.
A sketch by hand would explain better what you want to build -> thus you'll get better advice
Kliment,
Good idea, here is a front elevation. The stone wall in the lower right curves to follow the round turet and slopes in from the bottom to the top
Thanks,
John
undefined
It is very simple.
First make sloped wall (roof)
And than select wall and in pop up menu you cann choose the curved wall.
Or make curved wall and cut with roof, make roof invisible.
You have used roof, so you can measure the height very well, where you want.
Now I can understand.
You can use basic element library.
And use the solid-element.
LiHigh
Why not use Battered Wall under Extras\Accessories\Wall Accessories\
Howard Phua
Win 10, Archicad 19 INT
An old school method, before there were wall extras . Just use profiler:
undefined
