So I guess if you used Cut Planes or Marquee, the 2D Floor Plan object would also be cut.
What I would so is I would generate the 3D cut with the Cut Planes and save that 3D as an object.
Then I would place that object on a separate layer. Finally I would show in 3D only this saved object plus the objects showing the 2D Floor Plan lines.
