disabling fill on floor plan
On the floor plan window each time i insert an object/door/window it always comes with a fill/cut fill, how can i disable this option from the floor plan preference, it seems to be making the computer run slow, i checked the tool setting and work enviroment preference pages i couldn't find anything.
I am using Archicad 11
Thank you
Femi
2 Replies 2
Thomas Holm
Use Model View options? Or change the display setting to Symbolic?
Femi,
If you mean the background color of the object / window / door : they are calling fills by number : f.e. INT library : Solid fill = 64, Empty fill = 65.
Check Options > Attribute Manager > look for fills nr. 64 and 65.
In case you have other fills than solid or emty in your file at 64 and 65, you can open the AC11 template in the Attributes Manager window and copy / replace the correct fills...
Take care : localized libraries can have different numbers than 64 or 65 to call solid and empty !
