dormers
is there a minimum and maximum length for dormers? what are the implications?
13 Replies 13
Steve Jepson
? ? you can make a dormer any size you want.
thanks for your response..what i meant is to what extent it will be considered as 'engineered' ?
Steve Jepson
Adding a dormer will always require some level of engineering. How much will depend on what size and shape you make it. A typical complication is the foundation. Adding a dormer to an attic space sometimes adds a second floor. Now you have two stories wich complicates things sometimes if your stem walls and footings are only adequate for a single story building. This is not to hard to deal with unless you have a basement too.
it is a 1932 character house with 2- storey and a basement. we want to add dormers to the west and east side of the roof. attached is an idea . how can i add 2nd windows for each gable dormer? i don't seem to see any option in the window dimension of the gable dormer library part setting? is there a chimney library part? in the pict , the chimney is drawn using the column tool. why is it that it is not showing the penetration lines between the chimny and the roof?
please help.
oops...sorry posted the wrong pict. here the pict showing 2 gable dormer and the chimney between.
Steve Jepson
lsid wrote:
how can i add 2nd windows for each gable dormer? please help.
Step1: Get rid of the Dormer Object.
It really isn’t that useful. Draw your own walls and roofs so you can add any kind of windows you want. If your house was built in the 30s’ chances are your ridge board is only a 1x so you won’t be able to transfer any loads to it.
Hey….Are you an interior designer? I think there may be laws against aiding and abetting interior designers with structural questions. You may even have your dongle removed if anyone finds out you are trying to make working drawings.
thanks for your suggestion and it's interesting to note your warning or was that a threat ...
Steve Jepson
no threat, your "dongle" is the sofware protection key you plug int to access your ArhiCAD program. I was just tyring to poking a little fun at some stereo-typical attitudes you may be familiar with.
Anyway, try cutting a hole in the roof around the chimney to get the lines to show up better in 3D.
