dormers
is there a minimum and maximum length for dormers? what are the implications?
13 Replies 13
thanks steve for clarification and your little sense of humor.
how do you cut a hole in the roof? i have used the roof tool and not a slab tool and there is just the 'trim to roof' tool for the walls.
thanks.
Steve Jepson
I used to draw plans for a very good interior designer in Portland.
Its fun. just select the roof, click on the roof tool, and draw the hole. You can do the same thing for cutting holes in a slab.
thanks. i don't the "hole in roof" for ac7 version. anyways, i managed to create a hole on the roof using the spacebar. thanks.
Djordje
The same hole you can make in the slab, fill, zone ...
As to the dormers - there is a very good tutorial on them in the ArchiGuide Archives! Take a look!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
