Bill
elliptical column
is there a way to have a column that is elliptical in plan?
the circular column doesn't seem to allow for different x and y dimensions, and neither do any of columns or "basic shapes" in the library...
Bill Szustak RA
Principal, Springboard Design
ArchiCAD 25, macOS Ventura 13.4.1
6 Replies 6
Make an elliptical shaped fill and paste it
into the complex profile editor and use the
new profile with the column tool.
Peter Devlin
You can achieve that by applying a custom profile (an ellipse in your case) to your column.
Peter Devlin
Oops ... Didn't see your post Peter. Sorry.
Bill
THANKS!
Bill Szustak RA
Bill
Since the section of the column is going to be complex (recessed based, top and reveals) I realized I could also make a complex wall profile and then apply that via the magic wand to make a wall from a elliptical polygon. It ends up as a number of curved wall segments, but once they're grouped together it'll work fine.
Thanks again for the prompt replies!
Bill Szustak RA
Dwight
That unreliable server delayed my example, so here is how that wall/ellipse/complex profile thingy could look
Dwight Atkinson
