‎2015-11-19 06:51 AM
‎2015-11-19 10:00 AM
‎2015-11-19 04:53 PM
‎2018-03-26 07:07 AM
LaszloNagy wrote:
There is something else you can try.
Go to the Work Environment Dialog and in the Mode Rebuild Options page set the slider to the right of the Write Report checkbox to Full Report, then click OK to accept.
Then, when the error comes again, ARCHICAD may provide you with more detailed info about exactly which element gives the error. Hopefully it will provide you the ID of the element, after which you can simply go to the 3D Viewpoint and find the element(s) with Find & Select.
‎2018-03-26 07:32 AM
‎2018-03-27 06:11 PM
‎2018-03-28 10:30 AM
‎2018-03-28 10:43 AM
‎2018-04-04 04:24 PM
