explode a chain wall
I have created a chain wall but now I want to separate it to its parts but I don’t know how to do this. I will be so thankful if any one helps me.
1 Solution
Lingwisyer
Guru
Toggle groups (alt + g)
Ungroup (ctrl + shift + g)
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
Go to post
4 Replies 4
Do you mean that they are Composite or Complex Profile Walls and you want to break them down into their individual Skins as separate Wall elements?
No . when you want to draw a wall in plan view you can draw it with single line or poly line I selected the poly line which in ArchiCAD its name is chain wall as you can see in the attached picture. now I want to separate one side of the polyline. for example in AutoCad you can explode a polyline to separate it into single lines but in AC I don't have any idea. in picture two you can see that I have a chain wall that i want to separate it into single walls.
Lingwisyer
Guru
Yes that's exactly what I wanted. Thanks a lot for your help.
