‎2008-10-02 04:56 AM
‎2008-10-13 04:39 AM
Peter wrote:thanks for this method. it is almost done.
In the video, you can see in the navigator on the right that they are working on a worksheet, which is 2d only.
They have created it simply by copying and pasting a normal elevation, and editing all the fills manually.
An effective workaround tip, keeping everything live, is to -
- Switch to a side view - parallel projection in the openGL 3d window. Save it as a view. (Textures are visible in the 3d window, so ensure the model represents what you require, texture-wise.)
- Set up an elevation as normal, and change the settings to 'fill uncut surfaces' with 'Nothing' and turn on 'Vectorial Sun Shadows'
- On a layout bring in both the line elevation, and the view of the 3d window.
- Overlay the 3d window view so it is inline with the elevation, and resize it to suit. Send it to the back.
- Both the views will automatically update if something is edited, but everything will stay in line, shadows-and-all - Magic!
Hope that helps!
‎2008-10-13 02:17 PM
‎2008-10-13 02:27 PM
angus wrote:Use 'Resize' (Ctrl+k) and 'Define Graphicly' in the layout. Zoom in close for higher precision.
but i don't know how can i resize to suit them perfectly.
the scale are both in 1:100, but i dunno the 3d is a bit bigger than the elevation.
‎2008-10-14 06:40 PM
Peter wrote:Beeep! Wrong!angus wrote:Use 'Resize' (Ctrl+k) and 'Define Graphicly' in the layout. Zoom in close for higher precision.
The 3d window is not to a particular scale. For a higher resolution, use a larger sized window. You can specify the window size in the '3d Window Settings' dialog box. Anything over 2500 pixels wide doesn't look too bad.
‎2008-10-14 08:41 PM
Djordje wrote:
Beeep! Wrong!
The 3D window IS to scale. The problem is in copying the contents as a bitmap - that has to be resized properly.
‎2008-10-15 04:28 AM
