‎2004-06-13 02:16 AM
‎2004-06-13 06:57 PM
lsid wrote:Do you maybe have a circle within the ellipse?
I want to fill the ellipse with a solid fill but when I fill/spacebar on the ellipse, the fill turned out to be round instead of filling the ellipse. Am I missing something?
‎2004-06-13 09:20 PM
‎2004-06-14 08:34 PM
Geoff wrote:You can draw a circular now. Not starting from the center, though ...
You must admit that that lack of circular and elliptical fills is a glaring omission within the drafting tool set.
‎2004-06-16 12:57 AM
‎2004-06-16 08:07 AM
Erika wrote:thanks..where can i set the tolerance for the magic wand?
I have noticed the circular fill in the elipse before. It has usually been occurred when I am working in a very small elipse,which judging by the stud to its left, is the case here. Even if this detail is 3" = 1'-0", (large for imperail dimensions), you porbably won't notice it.
If I am not mistaken,the differnece is caused by the tolernces set for the magic wand. The lenght of the arc segments is longer than the angle of the line between the middle of the right side and the topmost point.
Ask yourself,
Will you notice the difference when printed?
If the answer is yes, then you can add node(s) to points along the fill and then adjust the fill to the elipse more fully.
If no....then don't worry about it.
‎2004-06-16 08:48 AM
‎2016-01-11 05:09 PM
