fill in the void!
Hi all, for presentation purposes, I am trying to fill voids with a solid fill that as shown in the attached diagram. What would be a reasonable approach to achieve this?
thanks
Petros Ioannou
Use the polygon method of the wall tool.
HTH
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Link
An even faster way:
1. Activate Fill Tool in toolbox;
2. Select all fills (ctrl+A);
3. Click and hold on a fill to invoke pet palette;
4. Select Add to Polygon from pet palette;
5. Hold spacebar down to invoke magic wand;
6. Click inside void of the current fill;
7. Repeat steps 3-6 for the rest of the voids.
Link.
