‎2017-10-06 02:37 AM
‎2017-10-06 02:52 AM
‎2017-10-17 10:03 AM
Barry wrote:Is there any way to create new vectorial fills? I found some old posts where was explained that it is possible to create new vectorial fills to the gdl-objects and then import fills to the project? Is it still possible and how it is actually done?
Again post moved to 'Working in Archicad'.
No a symbol fill pattern can not be turned into a vectorial fill.
Vectorial fills are pre-set in Archicad and all we can do is duplicate them and adjust the spacing and angle of the lines. Basically they are just a line or lines that repeat.
Symbol fills are the only ones we can truly customise with a pattern of our choosing.
‎2017-10-17 10:31 AM
Aki wrote:You will want to look at DEFINE FILL in GDL.
‎2017-10-17 01:53 PM
Once you have done this I believe it will appear in the Attribute Manager and you can then export it (save as AAT file).
Or if the GDL object you define the fill in is in your loaded library then the fill will already be there for your use.
But all you will probably be doing is creating versions of the existing vectorial fills which you can just duplicate and adjust the line spacing, rotation, scale, etc.
‎2017-10-17 02:09 PM
Aki wrote:I don't know the finnish template, but I'm pretty sure there is a soft insulation fill under "symbol fills".
I'm looking for a insulation fill pattern which looks like that. I think it is not possible to do that with any of the existing fills.
‎2017-10-17 02:42 PM
runxel wrote:Yes I have used symbol fills and created my own as well, but the problem with those are that the file size of exported DWG is huge, if there is even one symbolic fill in use.
Fills don't need to be a "vectorial fill" to get used in a BMAT.
‎2017-10-17 07:23 PM
‎2017-10-18 11:24 AM
"laszlonagy" wrote:
