2010-03-02 11:29 AM
2010-03-02 12:54 PM
2010-03-02 12:54 PM
2010-03-02 02:22 PM
laszlonagy wrote:i thought that this is the problem, 444/440, and it is. i was doing that pattern on square 3000/3000, and i only copy /paste it. so my problem is to create right pattern, but even i tried as much as i can, i'm not successful.
When you create the pattern on the Floor Plan, tile it next to itself on all sides. Then you will see whether the lines are really continuous.
Right now the size is 444 by 440 as seen in the Fill Settings Dialog.
Try to make the pattern on the Floor Plan 440 by 440.
2010-03-02 03:22 PM
2010-03-02 04:04 PM
laszlonagy wrote:
As I said, tile it next to itself on all sides.
Then the lines must be continuous as they go from one tile to the next.
You need to change the pattern so this condition is fulfilled. Then the result will be fine.
2010-03-02 04:18 PM
2010-03-02 05:15 PM
2010-03-02 05:43 PM
2010-03-02 05:46 PM
