We value your input!
here is the composite section
I have attached the composite section,I am trying to do a gfrc section with insulation .
7 REPLIES 7
Djordje
That should look like ... what?
Always post an example! And please do not use abbreviations unless you are absolutely sure everybody else around here understands them!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje wrote:
...And please do not use abbreviations unless you are absolutely sure everybody else around here understands them!
GFRC=glass fiber reinforced concrete...Its fairly common, hopefully most architects/draftspersons know the abbreviation
I don't know... in Dubai ???
woodster
woodster
Yes Woody, its probably used even more in an area like Dubai than where we are... They could refer to it as GRC though... I'm not really sure.
I do, however, get Djorde's point about abbreviations as I tend to get confused with alot of the basic "Chat" abrreviations.
Djordje
Dan wrote:
woodster
Oh, yes, it is very much used, and Dan is right - it is mostly called GRC here.
My point was - we all come from various parts of the planet, so what is obvious for me (door opening line, anyone?) is not so obvious or usual to you. Explaining ourselves fully helps to help.
Djordje
HP Omen
I second that. I frequently need to look up english words because I am not fully acquainted with architectural terminology.
It is mostly the unknown words and symbols which prevent understanding.
Aussie John
Back on topic I did experiment with make a wall with that type of fill and it worked well (make a fill with that pattern and inset in the wall composite, you may have to juggle the origin.) That fill pattern is used to represent insulation here.
The wrinkle came when i exported to DWG and the pattern converted into gazillion line segment ballooning the file size.
Cheers John
[/size]
