2005-03-01 08:51 AM
2005-03-03 09:21 PM
ashok_hj wrote:That should look like ... what?
I have attached the composite section,I am trying to do a gfrc section with insulation .
2005-03-03 10:18 PM
Djordje wrote:GFRC=glass fiber reinforced concrete...Its fairly common, hopefully most architects/draftspersons know the abbreviation
...And please do not use abbreviations unless you are absolutely sure everybody else around here understands them!
2005-03-04 02:53 AM
Dan wrote:I don't know... in Dubai ???Djordje wrote:GFRC=glass fiber reinforced concrete...Its fairly common, hopefully most architects/draftspersons know the abbreviation
2005-03-04 06:31 AM
woodster wrote:Yes Woody, its probably used even more in an area like Dubai than where we are... They could refer to it as GRC though... I'm not really sure.
I don't know... in Dubai ???![]()
woodster
2005-03-04 07:53 PM
Dan wrote:Oh, yes, it is very much used, and Dan is right - it is mostly called GRC here.woodster wrote:Yes Woody, its probably used even more in an area like Dubai than where we are... They could refer to it as GRC though... I'm not really sure.
woodster
I do, however, get Djorde's point about abbreviations as I tend to get confused with alot of the basic "Chat" abrreviations.
2005-03-06 12:31 PM
Djordje wrote:I second that. I frequently need to look up english words because I am not fully acquainted with architectural terminology.
My point was - we all come from various parts of the planet, so what is obvious for me (door opening line, anyone?) is not so obvious or usual to you. Explaining ourselves fully helps to help.
2005-03-06 10:55 PM
