hide detail boundary
Hi again
How do I hide the detail boundary in the detail window, but still show it in the source view, and so it stays hidden even if I rebuild detail from source view.?
Thanks in advance.
Mat
8 Replies 8
__archiben
the detail boundary and the detail marker boundary are two different things . . .
display the marker boundary in the source view and to show/hide the detail boundary globally throughout the project:
archicad 10 - 'element display settings' . . . 'show/hide detail boundary'
archicad 9 - 'display options' . . . 'show/hide detail boundary'
in archicad 9 the detail boundary gets saved with the view although it is an on-screen display option only (no output). in archicad 10 it's been taken out of the view settings for that reason and is a global element display setting throughout the project.
HTH
~/archiben
b e n _ f r o s t
Good afternoon
I must be stupid...wher is "element display settings"
Time for coffee.
Thanks, Mat
__archiben
sorry mate - my bad! i've modified my menus so much that i'd re-named that one! in archicad 10 it can be found under View>On-Screen View Options when using the standard profile . . .
it would be really helpful if you put your archicad version, build number and platform in a signature file in your profile - much like mine below. that way people would be able to help you quicker too.
~/archiben
b e n _ f r o s t
Thanks mate
Hi Archiben
Here's the picture to describe my problem;
__archiben
that's a 2D polyline created when the detail is created to show the clipping outline. probably useful if you've made an extremely irregular polygonal-shaped detail, but i agree that it's normally an extraneous element.
i'm afraid you'll have to manually delete it. it'll probably come back if you re-build from source too . . .
~/archiben
b e n _ f r o s t
SeaGeoff
Ace
Once true, but no longer. There is a new project preference (as of ArchiCAD 10) that gives you the option to create the detail boundary or not.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
__archiben
thanks geoff. good to know!
ben
b e n _ f r o s t
