Marker Elements on-screen-only parts
Does anyone know how to change the pen thickness of the Marker Elements' on-screen-only parts such as Section Limit Line, Elevation Line and Detail Boundary Line? I've gone to Options < Work Environment < On-Screen Options and changed the pen to a 0.05mm pen but the thickness doesn't change on my plans. RE: purple line in attachment.
Thank you in advance.
3 Replies 3
Patrick M
I think you want the pens in the marker settings, not the w/e settings.
But if not:
is there a graphic override rule changing the pens? I have a GO on all my views, since the markers routinely go dashed or double dashed, so I just override all marker lines/pens (since they were not actually built with adjustable parameters).
I'm wondering if we are talking about the same thing? I appreciate the input, but the pens in the marker settings change the pens for the marker itself, at least what I've found. The on-screen-only parts are in the W/E settings. I can change the pens in the W/E settings but the only thing that changes is the color of the pen type and not the thickness of the pen type. So, if I set it to pen 1 which is black at 0.5mm it only takes on the color. When I change it to pen 2, which is a purple at 0.05mm again, the color changes, but the pen stays the same thickness.
Bernhard Binder
Don't ask me why, but the thickness of boundary lines (Marker Range) is effected by pen #1 (sections, elevations) and pen #85 (interior elevations)
