hotspots dominating my unlinked elevations?
Ive never had this problem before, so i assume that i recently set some of my settings incorrectly somewhere down the line. but if you look at the image you will see what i am talking about, these hotspots are doubled, and trippled up, and takes forever to delete them.
Link to pic
http://www.yourimagehost.com/is.php?i=35696&img=HotSpots.jpg
thanxs in advance
10 Replies 10
Link wrote:
Woody simply generate any elevation with a window in it, then change that section to a Drawing and you will see hotspots turn up. They don't plot - they're just regular hotspots but they turn up!
Ve-e-r-r-r-y interesting You know, I NEVER unlink (no pun intended) my Elevations so I've never seen that before.
It does make it easier to Select whole elements but I think there should be a toggle to turn then off or on. I certainly would classify this as an annoyance!
Woody
