how can i fake an opening on plan when using SEO?
hi,
as we know if SEO is used the plan does not reflect a cut, what are the ways one can fake it on plan?
thanks,
joseph
4 Replies 4
In some cases the operator can help. A slab/roof/mesh can act as a cover fill but typically you'll still need a bit of line work. If its worth getting fancy you can save the operator as a library part and replace with same. This way you can make the plan view anything you want with just a single element to manage.
Otherwise it's fills and lines or the patch tool.
thanks i will try these,
also was thinking about placing an empty door when a wall is involved.
Jere
Using the wall niche tool is good too if the opening doesn't have to go through the entire thickness of the wall.
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Why not just turn the operator into a Window/Wallhole? Especially if it's repetitive through the project.
http://archicad-talk.graphisoft.com/viewtopic.php?p=189951
Then just save the object into the Embedded Library.
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
