how to display slab vectorial 3d hatching in floor plan?
hi!everyone
I need to show the ground fill in the floor plan, I can only show in the 3D document, but not easy to edit. And the plan of the furniture has changed.
Who can give me help, I am very grateful to everyone
In the slab settings there is an option show 'Cover fill'.
There is also an option to use the fill from the surface material so you don't have to set the cover fill type manually.
thx Barry Kelly,problem solved.
Cheers
