how to make tubular
attached is a frame i made out of simple slab but how do i make it round tube instead of square tube???
ac7 on xp
3 Replies 3
Petros Ioannou
Usually in ArchiCAD you can use profiler to achieve something like this.
If I remember correctly it exists in AC7 (the version you are working)
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
thanks but what is the profiler and how can I access to use it???
Erika Epstein
Its an add-on found in the goodies folder.
Drag it into the add-ons folder within archicad 7. Then when you open archicad it will be under the Tools menu
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
