yes, the model i posted used the complex profile method. it's easier with flat tube but i can't figure out how to use a round tube with the same method....i'm sure ac has thought of that....
Lilian Seow LEED AP | cSBA | CAPM | PMP AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
Use the custom profile editor to create the tube - then draw out the vertical and horizontal legs of the tube in plan - save each one as an object in the 3d window with the camera oriented to look down at what you want as the top end - then place the objects
