how to model using tube
Llian
here's a fairly easy but can't figure out how ...can someone help please!
how do i model a tube [ 1-1/2" dia tube with elbow of 4" radius?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
18 REPLIES 18
In the library under /special construction/basic shapes is a tube and elbow piece that will do what you want.
Llian
yes...i have tried them but just dont' know how to use the elbow....i just need to see a step by step video to understand.
It may be easier to use a profiled wall.
Llian
yes, the model i posted used the complex profile method. it's easier with flat tube but i can't figure out how to use a round tube with the same method....i'm sure ac has thought of that....
Llian
the model ..... with flat tube
Use the profile editor to make any shape you want.
Llian
thanks matthew.....but....how?
Use the custom profile editor to create the tube - then draw out the vertical and horizontal legs of the tube in plan - save each one as an object in the 3d window with the camera oriented to look down at what you want as the top end - then place the objects
I recommend not making the tube hollow unless you need to. It doubles the number of polygons.
