We value your input!
how to toggle through elements?
in archicad 9, where i had several elements on top of each other i could keep clicking in the same place and it would toggle through the elements (such as when i have a roof, wall, and parapet line all on the same line/plane when in 2D mode). in archicad 10 this function to toggle through the elements has gone. if i keep clicking like i used to, it brings up the properties of the first item selected.
is there a way to change it back to the way i could toggle on archicad 9? or some other way?
10 REPLIES 10
hold your mouse over, then use TAB sequense.
thanks!
shame that graphisoft didnt leave things like that like they were before.
Dwight
percybigun wrote:
thanks!
The new way actually works better. For once.
Give my regards to Bilbo.
Dwight Atkinson
yeah i suppose its better when you get used to it.
bilbo bigun's? percybigun means something different entirely!
TomWaltz
Once I got used to TAB, I did not even once miss the old click-until-you-get-the-right-one method, especially since it almost never worked if you have multiple elements already selected.
Tom Waltz
Dwight
I am certain that it does, but that is how the mind works after an all-nighter.
Enlighten me.
Dwight Atkinson
clicking works with me!
You must be Ivor's brother
its kinda like ivor bigun but here in the UK percy means as in "pointing percy at the porcelain". its a daft hotmail address i came up with years and unfortunately it became my internet handle!
