Here is an idea:
If it is about Doors for example, then create a Door and inject into it the Favorites of your choice.
Then you should create a Door Schedule that list all parameters you need matching.
Then generate this Door Schedule. Make sure that the "Show uniform items as a single entry" option is checked.
Then you can find in the list the line that matches to your Favorite.
Select the line and click the "Select in 3D" button above the Schedule.
I hope this explanation makes sense.
