interior wall fill
dhnguyen
I have hundreds of interior walls. I'd like to select them all at once and change the fill from 1 color to another, please show me how to do that.
thank you.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
If they are 'standard' walls you can just select all and swap the fill for another one.
If they are 'Composite' walls you can select all and swap the composite for another but make sure it is the same width composite or the wall width will change.
If you don't have another composite to swap to you can edit the existing composite or create a new one and swap to that.
If they are 'complex profile' walls you will need to swap for another profile or edit/create a new one.
Guru
If they are all on the same layer/s, you could use the find function to select them. eg. Walls => Wall - Internal
Ling.
dhnguyen
thank you!
DNguyen
ArchiCAD 18- 25
