2013-07-31
06:39 PM
- last edited on
2023-05-24
09:11 AM
by
Rubia Torres
2013-07-31 10:31 PM
2013-07-31 10:46 PM
2013-08-01 02:50 AM
s2art wrote:
Jonathan
You can create a fill pattern by drawing with lines at an appropriate scale, copy the lines, then paste into a new symbol fill. You assign this fill to a material in the Vectorial Hatching section of the material's settings when in the Internal Engine options. (You do not assign the fill to the wall itself).
2013-08-01 05:15 AM
Jonathan wrote:Select the fill pattern in Material Settings dialogue, as shown below.
How do I get the 2d line work to be added as a fill that I can assign to a
surface?
2013-08-01 05:52 AM
s2art wrote:Jonathan wrote:Select the fill pattern in Material Settings dialogue, as shown below.
surface?
A tip when you create your fill pattern. Make sure your pattern is seemless when it repeats by having some of the stones continuing thru' across the edge. You might also have too many lines too close together for a good result.
2013-08-01 05:56 AM
2013-08-01 06:14 AM
2013-08-01 06:15 AM
2013-08-01 07:20 AM
