Like the subject says, is it possible to somehow Lock for instance a wall or a slab to a certain floor? The issue I'm having, is that I create some walls, say a rectangle, linked to a certain floor. But then I need to lower the base of one wall, say, 50cm, though keeping the height the same. But when I lower the wall, it pops Down to the floor beneath. The height is correct, but it disappears from the floor plan of the original story, and resurfaces on the story below.
Up til now I have adjusted it back to the storie its supposed to be on manually, but is it a way to prevent that from happening in the first Place?
.Thag
Windows 10, Archicad 27,28 and 29
