Corbin
macOS arm - full screen mode - tracker and coordinate input
Hi there!
In full screen mode the window 'tracker and coordinate input' disappears. After pressing arrow up or down will popup one window for input. I tried to switch the video card mode & changing the appearance of the Tracker, but nothing helps.
Is there any way to fix this?
This is present in the 27th and 28th versions, as far as I know.
Thanks!
MacBook Pro M3 max, last OS (doesn't matter)
10 Replies 10
Pedro Melo
Does this happens when using a default Work Environment (WE)? Try it with a default WE.
Corbin
Unfortunately the same results.
It's a very strange no one haven't same problem or people don't work in fullsreen mode?
Or do people who work not visit forums?
Pedro Melo
I'm on a M1 Max MacBook Pro using macOS Sonoma (14.6.1).
Tried it on AC27 and AC28 without any issues (both on the MacBooks screen and a mirrored Apple Studio Display). Are you using two displays contemporarily?
Is it possible that the tracker is on the second screen?
Corbin
I have MBP only
Corbin
Recently (two years) I reinstalled the operating system cleanly twice and used versions 27 and 28. It was always the same problem.
Pedro Melo
Have you tried to turn "off" then "on" the tracker?
Also, are you using any special add-on?
Pedro Melo
Sorry for asking, are you installing AC 27's or AC28's apple silicon version?
Corbin
yes and tryed to use custom appearence (((
Pedro Melo
