rob2218
merging or combining plines that are overlapped or end-end
is there a way of merging or combining plines that have overlapped or are simply two plines end to end?
I know in the other 2D program from Autodesk...there was a "join" function that allowed ends of plines to 'join' and become one pline.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
15 Replies 15
Dave Seabury
Try selecting the Polyline tool, and then magic wand the lines that form the closed loop.
Worked for me
David
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
rob2218 wrote:
So...what i was hoping was that I could grab a bunch of plines...say from a manufacturer like a window sill profile and make it into ONE pline...but since the window sill (as an example) is a closed loop...it won't work....again..bummer.
Yeah, that used to work, but is apparently broken now. Hadn't noticed until now.
Just experimented with two multi-sided polylines. They would not Unify. But, when I exploded them to individual segments (still individual polylines - if you want line use the Linework Consolidation command) they did join to a single multi-sided polyline.
Katalin Borszeki
Dear Stuart, the problem you mentioned with unifying closed polylines was a bug in ARCHICAD 18 which has been fixed only in ARCHICAD 19. Thanks, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Excellent, thanks.
Katalin Borszeki
Dear Stuart,
The problem you mentioned with unifying closed polylines was a bug in ARCHICAD 18 which has been fixed in ARCHICAD 19 only.
Katalin Borszeki
GRAPHISOFT
