โ2018-08-02
12:26 AM
โ2023-05-24
08:20 AM
Rubia Torres
โ2018-08-05 11:07 PM
LaszloNagy wrote:For me, the Curtain Wall, like the Stair Tool, or any other tool is only useful to the extent that it works with an Interactive Schedule. Can you schedule the parts of a Curtain Wall ?
With ARCHICAD 22 the renewed Curtain Wall Tool may actually be a good and feasible solution for creating the Wall Framing.
โ2018-08-05 11:50 PM
Steve wrote:Looks like it is possible. Will be trying this approach soon.
โ2018-08-07 11:59 AM
โ2018-10-24 10:26 PM
LaszloNagy wrote:I have herd that rumor before. I have yet to see an example of it that is integral with Schedules.
โ2018-12-05 12:30 PM
โ2019-01-22 07:29 PM
โ2019-02-07 11:52 AM
alexwang32 wrote:The rafter also works better in many situations for Beams with an opaque background if you what it.
...It didn't occur to me that Rafters could made great wall plates, which shows that there are so many ways to get creative in ArchiCAD. Next time I'll trying modeling walls with mesh![]()
โ2020-11-02 02:37 PM
Steve wrote:Looking at your post, you have a very neat surface for the Tyvek vapour barrier in the 3D example. Could you share how to achieve that surface please? I am in UK using AC24 INT.
I don't think there are any 3rd party tools for this that are any better than what you can do with out them. Also, I don't fined the wall framing accessory in ArchiCAD useful either.
The trick to being efficient about this is to be using pre-modeled assemblies for door, window, and stair framing that you just tweak a little as needed. I like to place all the trimmers and kings studs first since they help me locate the doors and windows, then multiply the studs. I don't keep the trimmers, king studs, or cripples in my pre-modeled assemblies.
The reason to model the framing has very little to do with providing the Carpenter/Chippy with how-to instructions. However, it can reduce the need for skilled labor which also saves money. One less foreman to hire over the course of the project will alone save you the entire cost of generating the Framing Model.
There are several reasons to do it that will alone save more than the cost of doing it - in certain situations. Architects typically have no reason to do this since they do not benefit directly from the projects costs or cost savings. Contractors/Builders always do. The people who hire me do make Framing Models for their projects do it because it saves them a lot more than it costs them. This is my motto: "A good set of Plans will always save you more than they cost you." And that savings needs to be verifiable. Which is perhaps the biggest reason model the Virtual Building.
Another reason to do this is because it can significantly reduce the Engineers billable hours by making sure he does not need to spend hours trying to figure out a solution to the Architects 1/2 baked idea that almost works, but not quite. Also, this is the most efficient way to verify the Schedules. I usually place the Interactive Schedules right next to the framing diagrams and/or a 3D view of what is in the schedule. You can put a check mark on every part and the schedule to visually verify them. This is more important for some projects than others. Plans that include this kind of thingwillproduce lower bids from the subs who will not need to pad the bid for the unknowns (there aren't any).
To say nothing of the savings you realize with just routine communications. Everyone saves time and money from that.
โ2020-11-02 04:48 PM
โ2020-11-03 03:43 PM
