Mats_Knutsson
Mentor
morph question - window collar
See attachment
AC 25 SWE Full
5 Replies 5
Erwin Edel
For these sort of things I prefer the slightly more intelligent option of (stretchable) custom profiles. To prevent elements interacting I ussually put these on a layer with a different intersection group number from the wall.
For this shape you would need 2 profiles, 1 for the corners and 1 for the middle bit. If you make them stretch vertically, you can use one profile for all windows.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Mats_Knutsson
Mentor
Hi Erwin,
I'm not sure I'm following how to do this with CP?
Is there anywhere I can dump a short vid to explain?
/Mats
AC 25 SWE Full
Erwin Edel
Here's a screenshot of stretchable CP.
You'll need a 'corner' bit that is both shapes connected.
Just extrude 3 CP walls (2x corner + middle).
Depending on how many times you would use this there is another option to just code a GDL object for it. I generally weigh the hours spent adjusting these things to the hours spend coding (I'm no GDL guru) and sometimes make the leap to make a custom object.
www.leloup.nl
Erwin Edel
CP has the benefit of super easy editing though.
www.leloup.nl
Mats, do you know that you could create a Morph in a Section Viewpoint?
I would have just cut a temporary section through the Window, and would have drawn the section of the Morph, then pulled it in 3D.
Then I would have done the same for the vertical portions in Floor Plan.
Then I would have used Morph SEOs to create one Morph out of them.
