morph question - window collar
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2014-04-09
12:09 PM
2023-05-24
07:27 PM
Rubia Torres
2014-04-09
12:09 PM
AC 25 SWE Full
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-04-09 04:07 PM
2014-04-09
04:07 PM
For these sort of things I prefer the slightly more intelligent option of (stretchable) custom profiles. To prevent elements interacting I ussually put these on a layer with a different intersection group number from the wall.
For this shape you would need 2 profiles, 1 for the corners and 1 for the middle bit. If you make them stretch vertically, you can use one profile for all windows.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-04-09 05:49 PM
2014-04-09
05:49 PM
Erwin wrote:Hi Erwin,
I'm not sure I'm following how to do this with CP?
Is there anywhere I can dump a short vid to explain?
/Mats
AC 25 SWE Full
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-04-10 10:28 AM
2014-04-10
10:28 AM
Here's a screenshot of stretchable CP.
You'll need a 'corner' bit that is both shapes connected.
Just extrude 3 CP walls (2x corner + middle).
Depending on how many times you would use this there is another option to just code a GDL object for it. I generally weigh the hours spent adjusting these things to the hours spend coding (I'm no GDL guru) and sometimes make the leap to make a custom object.
www.leloup.nl
Windows 10 Pro
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-04-10 10:29 AM
2014-04-10
10:29 AM
CP has the benefit of super easy editing though.
www.leloup.nl
Windows 10 Pro
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-04-11 07:05 PM
2014-04-11
07:05 PM
Mats, do you know that you could create a Morph in a Section Viewpoint?
I would have just cut a temporary section through the Window, and would have drawn the section of the Morph, then pulled it in 3D.
Then I would have done the same for the vertical portions in Floor Plan.
Then I would have used Morph SEOs to create one Morph out of them.
