2010-09-05 12:36 AM
2010-09-05 01:05 AM
2010-09-05 03:10 AM
2010-09-05 03:38 AM
Matthew wrote:Aloha Matthew,
There is no single best way. It depends on the project.
I have used the multiple file approach as well as linked multiple files. This approach is generally best in early phases.
You can also use Teamwork and create multiple drafts from the same shared file (I haven't tried this yet in 13 or 14 but imagine it should still work. This is useful for significant alterations of largely settled designs and is good in the design development phase.
For minor alternates I usually use layers. This is really for very limited scope alternates though, like two roof options for the side porch. Anything even remotely complex can quickly turn this into a major pain.
For the first two methods the only way I know to keep track of the alternates and changes is with notes. On a Mac these can be put into the "Spotlight Comments" field in the Finder which allows you see the comments in list view.
I'm not sure that this aspect of design practice can really be highly automated. The parameters are tremendously complex.
2010-09-05 04:34 AM
johncassel wrote:I believe it has been discussed here before so a search might turn up something useful. It's been a while since I've done it so I don't recall all the details.
I am intrigued by the Teamwork idea using drafts. How can I learn more about this option?
2010-09-09 02:47 AM
2010-09-09 02:59 AM
2010-09-09 04:02 AM
snapcrackle wrote:And we know how well that's working out...
TW2
Look at the AC Collaboration Guide Part 2, Chapter 7, step 5. the title of this section is, drum roll ...
Version Management with Mark-Up. It specifically addresses following multiple ongoing versions in the same model.
And, "compare several design proposals to each other", nice after dinner treat, huh?
Just another tool in the arsenal.
Snap
2010-09-09 04:20 AM
2010-09-09 10:53 PM
