2004-05-17 10:03 PM
2004-05-17 10:12 PM
2004-05-17 11:44 PM
2004-05-18 07:48 AM
ashley wrote:
could you teach me how to use ArchiCAD to do offset? Thank you!
TomWaltz wrote:See above
User Guide Volume 2, Page 29,
2004-05-18 05:01 PM
ashley wrote:Actually, no. ArchiCAD can do offsets, but it's not "just like AutoCAD". ArchiCAD doesn't offset existing objects, it will only offset the object you are currently drawing.
can ArchiCAD do Offset just like AutoCAD?
2004-05-18 05:33 PM
Jay wrote:Depends on what you do. It can do this, OR create a new object based on the existing one. What exactly do you want to do?ashley wrote:Actually, no. ArchiCAD can do offsets, but it's not "just like AutoCAD". ArchiCAD doesn't offset existing objects, it will only offset the object you are currently drawing.
2004-05-18 06:08 PM
Djordje wrote:I would like to be able to offset an existing polyline. There are situations where the polyline has existed for days, but today I need to offset it by some distance. The only solution I could see was to aquire the polyline settings with the syringe, then redraw the polyline using the magic wand and the offset, then erase the original. If there is a way to just offset the existing original, that would be much easier.Jay wrote:Depends on what you do. It can do this, OR create a new object based on the existing one. What exactly do you want to do?ashley wrote:Actually, no. ArchiCAD can do offsets, but it's not "just like AutoCAD". ArchiCAD doesn't offset existing objects, it will only offset the object you are currently drawing.
2004-05-18 06:20 PM
2004-05-18 06:37 PM
2004-05-18 07:45 PM
