‎2004-05-17 10:03 PM
‎2004-05-18 08:24 PM
‎2004-05-18 08:29 PM
‎2004-05-18 09:37 PM
ashley wrote:Type r and input the offset value when you start offsetting.
I have more problem with the offset in sertain demantion. The line will even longer or shoter, but with same curve.
‎2004-05-19 10:01 AM
‎2004-05-26 05:38 PM
‎2004-05-26 06:10 PM
Amanda wrote:I have no trouble offsetting a polyline. Select the polyline tool, select the offset button, and space bar click on the spline or polyline.
We're having problems offsetting a spline. We've also drawn it as a polyline with curves and it still won't offset. That nifty offset in the pet palette doesn't come up with all of the tools unfortunately. Sometimes it just gives you the option to offset one side at a time. The only thing we've gotten to work is to explode the spline or polyline into arcs and offset each arc individually. This takes forever and is a little cumbersome because an arc offset seems to be by its radius so you have to know the starting radius and then add whatever you want to offset.
Has anyone been able to offset a spline or a curvy polyline?
‎2004-05-26 08:30 PM
Amanda wrote:Screenshot? Can you send a zipped MOD?
‎2004-05-31 09:40 PM
‎2004-06-01 07:07 PM
‎2004-06-01 07:11 PM
