order of operations
what is ones opinion on the order of operations you should use to construct a 3d model. for example slab, walls, roof...... or roof, slab, walls, ........
3 Replies 3
TomWaltz
Not to sound too vague, but whatever works best for your situation.
If you have a building outline to work with, go for slabs first.
If you have a plan layout, go for walls first.
If you have a roof plan to start from, do roofs first.
Tom Waltz
Link
If you model your walls or slab first, you can magic wand in the other and the roof easily afterwards. But it does depend on the situation and your own preference. A lot of people find that creating walls first is the most logical way to set out their building.
Link.
Aussie John
Usually the plan hasnt settled down when first being CADed so to me makes sense to start with walls. Things like slabs come later.
Cheers John
[/size]
