pen set- one decimal place
I have a problem with adjusting PEN SET-s. It shows only one decimal place no matter I use mm or Pt. In attributes manager it shows both decimal places but where I'm suppose to adjust them there is only one. Pls. help because I'm trying to finally set my template file.
David Maudlin
arhimag:
Look under Preferences > Working Units & Levels > Angle & Text Size Decimals in Dialog Boxes: you have options from 0 to 4.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
thank you very much. your advice helps but when we open again the file, in pen set window there is again only one decimal place no matter what is set in settings where you suggested. i don t understand is something wrong withe file.
i will attach signature soon. tkx for advice.
